ERROR
No features present in cover(s), mapextent unchanged
Solution or Workaround
Summary
This error occurs when running the MAPEXTENT command with xmin, ymin, xmax, and ymax values:
No features present in cover(s), mapextent unchanged.
Cause
The cause is an error in specifying the x,y coordinates, the maximum value of either x or y is smaller than the minimum value.
Solution
Make sure the maximum coordinate values are larger than the minimum values.
Article ID:000001683
Software:
  • Legacy Products
Get help from ArcGIS experts
Contact technical support
Download the Esri Support App
Go to download options
Discover more on this topic
