ERROR
NDP error - invalid number integer overflow
Solution or Workaround
ARCPLOT PLOTZOOM and ARC DRAW sometimes stop drawing or draw with a purple spike. Other times they produce the following messages:
"NDP error - invalid number integer overflow or 0/0
see section b.2 F77L manual
called by Draw
called by move
called by fdwplt
called by fdwplp
called by fdwplz
called by exe811
called by execut
called by arcplt"
The latter requires a reboot.
Cause
The default display driver IBMVGA.SYS.
Solution
Change the display driver to HRVGA.SYS -STANDARD 640x480 VGA.
Article ID:000001631
Software:
  • Legacy Products
Get help from ArcGIS experts
Contact technical support
Download the Esri Support App
Go to download options
Discover more on this topic
