ERROR
My Esri: Unfortunately your request could not be completed. Please try again
First Published: February 19, 2024
Last Published: July 23, 2026
Error Message
When attempting to authorize a Concurrent Use license offline on the My Esri (Secure Site Operations) webpage, the process fails after uploading the authorization.txt file, and the following error message is returned:
Error:
Unfortunately your request could not be completed. Please try again.
The Unfortunately your request could not be completed. Please try again error message
Cause
  • This is a known issue when using ArcGIS License Manager 2023.0 to generate the authorization.txt file, caused by BUG-000162359.
  • The authorization request has exceeded the maximum number of available licenses, or the machine has undergone an incomplete recovery of licenses. This can occur if My Esri lists two different MAC addresses for the same UMN ID.
Solution or Workaround
Depending on the cause, the workarounds provided are applicable.
The Concurrent Use license type and ArcGIS License Manager were deprecated on July 1, 2025. For more information, refer to Deprecation: Concurrent Use License Type and ArcGIS License Manager.
Upgrade ArcGIS License Manager
Upgrade ArcGIS License Manager to the latest version. Refer to License Manager Guide: Upgrading License Manager software from 2018.1-2025.0 to ArcGIS License Manager 2025.1 for instructions.
Clear the trusted storage and recover the licenses
If the authorization request has exceeded the maximum number of available licenses, perform the following solution:
  1. Clear the trusted storage on the machine. Refer to How To: Clear or delete trusted storage for concurrent-use and single-use licenses for instructions.
  2. Recover the lost licenses. Refer to How To: Recover lost licenses from My Esri for instructions.
Article ID: 000032040
Software:
  • Other
  • ArcGIS Pro
Get support with AI
Start chatting now
Related Information
Discover more on this topic
Get help from ArcGIS experts
Contact technical support
Start chatting now
Go to download options
