ERROR
MKDB returns 'Unable to create database at location'
Error Message
Attempting to create an ArcStorm database with MKDB causes:
C:\asdatabases>mkdb testdb aspestos
Unable to create database at location c:\asdatabases\testdb.
Database location is not an NTFS format file system.
Cause
ArcStorm only supports NTFS disks; therefore, databases cannot be created on FAT drives.
Solution or Workaround
To check the type of drive you are attempting to create a database on:
Select the drive letter in Windows Explorer > Right-click > Select Properties > General Tab.
File System: will be described as either FAT or NTFS.
Article ID:000002247
Software:
  • Legacy Products
  • ArcMap 8 x
Get help from ArcGIS experts
Contact technical support
Download the Esri Support App
Go to download options
Discover more on this topic
