ERROR
[Microsoft] [ODBC Microsoft Access 7.0 Driver] Too few parameters
Error Message
When adding a Microsoft Access table to ArcView using an SQL connection, the following error may occur:"[Microsoft] [ODBC Microsoft Access 7.0 Driver] Too few parameters.
Expected 1
SQL syntax error"
Cause
The field names contain spaces or special characters.
Solution or Workaround
In the select clause of the SQL statement, add square brackets around the table name and field name for fields with spaces or special characters. For example:
Code:
select [table1].[field-1], [table1].[field 2], table1.field3
Article ID:000002871
Software:
  • Legacy Products
Get help from ArcGIS experts
Contact technical support
Download the Esri Support App
Go to download options
Discover more on this topic
