ERROR
[Microsoft] [ODBC Microsoft Access 7.0 Driver] Error in assignment (null)
Error Message
This error occurs when adding an Access table to ArcView using an SQL connection with a 'Where' clause in the SQL statement:[Microsoft] [ODBC Microsoft Access 7.0 Driver] Error in assignment (null)" which is followed by a "SQL Syntax Error
Cause
Incorrect syntax in the SQL statement.
Solution or Workaround
Refer to the Microsoft Access Help documentation to ensure you are using the correct syntax.
Article ID:000003864
Software:
  • Legacy Products
Get help from ArcGIS experts
Contact technical support
Download the Esri Support App
Go to download options
Discover more on this topic
