ERROR
Method 'Movenext' of object '_Recordset' failed
Error Message
Looping through a database schema ADO recordset using the ESRI OLE DB provider returns "Method 'Movenext' of object '_Recordset' failed" when attempting to move to the next item in the recordset.
Cause
If the ADO connection has been made to an ArcSDE Geodatabase which includes custom COM objects and the class extensions for those objects have not been installed on the local machine, the movenext method on the database schema rowset (recordset) will fail when these objects are encountered.
Solution or Workaround
If it is not feasible to install the custom object extensions locally, trap for the error and resume the loop through the recordset.
Code:
On Error GoTo Err:
Do Until adors.EOF
adors.MoveNext
Loop
Exit Sub
Err:
MsgBox Err.Number & Err.Description, vbExclamation
Resume next
End Sub
Article ID:000002585
Software:
  • ArcMap 8 x
Get help from ArcGIS experts
Contact technical support
Download the Esri Support App
Go to download options
Discover more on this topic
