ERROR
Maximum number of stacked commands reached
Error Message
During an SML process, the message "Maximum number of stacked commands reached" appears.
Cause
PC ARC/INFO supports up to nine levels of SML nesting. If this limit is exceeded, this message will appear.
The message also will occur if a POPUP SML calls itself. If a loop is used, once the POPUP calls itself after the ninth time, the program will halt with the message.
Solution or Workaround
The SML program flow must be modified to avoid exceeding nine levels of nesting.
Article ID:000005556
Software:
  • Legacy Products
Get help from ArcGIS experts
Contact technical support
Download the Esri Support App
Go to download options
Discover more on this topic
