ERROR
Maplex is copy protected by a hardware key
Error Message
This message is returned when starting Maplex:
"Maplex is copy protected by
a hardware key that must be attached to your computer", then the "Password
override" window appears.
Cause
There are two possible causes:
1. The hardware key is not plugged in properly.
2. The Sentinel Driver needs to be installed.
Solution or Workaround
  1. Make sure the hardware key is plugged into the back of the computer. Restart Maplex.
  2. If the message occurs again, run the Maplex Hardware Key Program from the Start menu. This brings up the Sentinel Driver Setup Program. Select Install Sentinel Driver from the Functions menu, then restart the Maplex.
Article ID:000001999
Software:
  • Legacy Products
Get help from ArcGIS experts
Contact technical support
Download the Esri Support App
Go to download options
Discover more on this topic
