ERROR
Machine 'https://<machine name>' returned an error. 'Invalid Token.'
Error Message
When attempting to configure a standby Data Store in a high availability environment, the following error message is returned:
Error:
Machine 'https://<machine name>'/arcgis/datastoreadmin returned an error. 'Invalid Token.'
Image of the error message
The ArcGIS components in the high availability environment are:
  • ArcGIS Server 10.6.1 - High Availability
  • Portal for ArcGIS 10.6.1 - High Availability
  • ArcGIS Data Store 10.6.1 - High Availability
  • Federated Environment
Cause
This issue occurs if the Data Store is configured and created before federating with Portal for ArcGIS, and once Portal for ArcGIS replaces the ArcGIS Server's identity store, the credentials used to create the Data Store no longer exist.
Solution or Workaround
To resolve this issue:
  1. In Windows, run the Windows Command Prompt as an administrator and navigate to:
    C:\Program Files\ArcGIS\DataStore\tools
  2. Run the following command:
    unregisterdatastore.bat –-stores relational –-prompt no
  3. Navigate to the Data Store Configuration Wizard for the primary ArcGIS Server machine, and re-register the primary Data Store. Below is an example of the Data Store Configuration Wizard directory:
    https://<FQDN>:2443/arcgis/datastore
  4. Navigate to Server Manager and verify that the primary Data Store validates successfully.
  5. Once verified, return to the Data Store Configuration Wizard for the standby ArcGIS Server and register the standby Data Store.
Article ID: 000020090
Software:
  • ArcGIS Data Store
  • Portal for ArcGIS
  • ArcGIS Server
Get support with AI
Start chatting now
Related Information
Discover more on this topic
Get help from ArcGIS experts
Contact technical support
Start chatting now
Go to download options
