ERROR
LoadLibrary failed with error 87: The parameter is incorrect
First Published: February 8, 2019
Error Message
When opening or creating a project or map document in ArcGIS Pro or ArcMap, the following error message is returned:
Error:
LoadLibrary failed with error 87: The parameter is incorrect.
Image of the error message
Cause
This issue occurs due to the machine's graphics card configuration.
  • The graphics card driver is out-of-date.
  • There are conflicting graphics cards in the machine.
  • If using Remote Desktop Protocol (RDP) to connect to a remote machine, there could be a conflict between the video card specified by the RDP connection, and the one used by ArcMap on the remote machine. RDP is connecting by default to a built-in Intel video card, and not the video card used by ArcMap.
Solution or Workaround
Depending on the cause, either:
Article ID: 000020069
Software:
  • ArcMap
  • ArcGIS Pro
Get support with AI
Start chatting now
Related Information
Discover more on this topic
Get help from ArcGIS experts
Contact technical support
Start chatting now
Go to download options
