ERROR
License Manager Error: 0193%1 is not a valid Windows application
Solution or Workaround
Error Message:
The following error message occured:
Cause:
NT Services could not resolve the long file name in HKLM--> System-->
Current Control Set--> Services ESRI License Manger Image Path that
points to lmgrd.exe.
Solution:
Warning:
WARNING: The instructions below include making changes to essential parts of your operating system. It is recommended that you backup your operating system and files, including the registry, before proceeding. Consult with a qualified computer systems professional, if necessary.
ESRI cannot guarantee results from incorrect modifications while following these instructions. Therefore, use caution and proceed at your own risk.
1.- Using the Registry editor, change the Image Path from a long file name to
an eight character DOS name.
2.- Open the registry editor from the Run dialog box or DOS command prompt by typing:
regedit
3.- Navigate to HKLM-->System-->Current Control Set--> Services ESRI License Manager.
4.- Double click on Image Path to bring up a string editor. The Image Path
reads: "C:\Progam Files\ESRI\License\lmgrd.exe". Change the Image Path to read "C:\Progra~1\ESRI\License\lmgrd.exe"
The ESRI License Manager will now start from services as well as bootup.
Article ID:000001426
Software:
  • Legacy Products
Get help from ArcGIS experts
Contact technical support
Download the Esri Support App
Go to download options
Related Information
Discover more on this topic
