ERROR
Library $USEREXT/xxxx.dll does not have a LibInit function
Error Message
This error can occur when trying to load a user created extension:
"Library $USEREXT/xxxx.dll does not have a LibInit function"
Cause
User-created DLLs don't apply to the dependency list in the Extension Make script. Only extensions (.avx files) and ESRI created DLLs (avdlog.dll, avgrid.dll, avnet.dll, and so forth) are to be used in the dependency list of the Make script.
Solution or Workaround
If you want to use user-created DLLs, you need to use the DLLProc requests in your Avenue scripts. These Avenue scripts can be part of the extension you create.
See the ArcView help topic "Extension Dependencies" for more information.
Article ID:000004067
Software:
  • Legacy Products
Get help from ArcGIS experts
Contact technical support
Download the Esri Support App
Go to download options
Discover more on this topic
