ERROR
LDAP: error code 1 - 000004DC: Ldaperr: DSID-0C0907C2, comment: In order to perform this operation a successful bind must be completed on the connection
Error Message
When searching for users or groups after configuring Integrated Windows Authentication (IWA) for a portal, the following error message is returned:
Error:
LDAP: error code 1 - 000004DC: Ldaperr: DSID-0C0907C2, comment: In order to perform this operation a successful bind must be completed on the connection.
Cause
The information provided in the security configuration JSON file is not reaching out to the correct machine because the parameter for the domain controller is not specified.
Solution or Workaround
After configuring IWA for the portal, access the security configuration JSON file and update the domainControllerAddress parameters. Refer to Portal for ArcGIS: Configure the domain controller used by Portal for ArcGIS for steps to do this.
Article ID:000021045
Software:
  • Portal for ArcGIS
Get help from ArcGIS experts
Contact technical support
Download the Esri Support App
Go to download options
Related Information
Discover more on this topic
