ERROR
LAB and PAT do not agree
Solution or Workaround
Summary
This error occurs in ARCEDIT:
Cause
This error message is generally caused by:
1. Labelerrors, usually duplicate labels in polygons.
2. Coverage IDs were updated in INFO or TABLES and IDEDIT was not run afterward.
3. Cover.pat was sorted in INFO or TABLES without sorting back on cover#.
For example: You add arcs that don't close to a polygon coverage, add labels to the unclosed polygon, and clean the coverage to update the PAT file. As result, the unclosed polygon will cause the PAT and LAB to not agree, and for another polgyon to have two labels; thus, the data is scrambled.
Solution
For arc attribute table:
Code:
Tables
select cover.aat
calculate cover_id = cover_ - 1
Code:
IDEDIT cover line
BUILD cover line
For polygon attribute table:
Code:
Tables
select cover.pat
Code:
IDEDIT cover polygon
Build cover polygon
Fr point attribute table:
Code:
Tables
select cover.pat
Code:
IDEDIT cover point
Build cover point
The user defined items will scramble after editing if you have not followed the correct procedures for adding features to a coverage.
Article ID:000001701
Software:
  • Legacy Products
Get help from ArcGIS experts
Contact technical support
Download the Esri Support App
Go to download options
Discover more on this topic
