ERROR
java.lang.NullPointerException - ArcIMS
Error Message
When clicking on any layer in the TOC, or Table of Contents, of a custom Java Viewer, the following error occurs in the java message console:"java.lang.NullPointerException."
Cause
This error occurs if any of the tools in the Zoom and Pan ToolBar are unselected while designing the custom Java Viewer site using ArcIMS Designer.
When creating the Web site using Designer, at one point the tools to include in the Web site can be selected. By default, all the tools in the Zoom and Pan ToolBar are selected. If any of the tools are unchecked, the 'All' check box becomes unchecked itself. If 'All' is unchecked, the error occurs.
Solution or Workaround
Manually edit the JavaScript file in the Web site to eliminate this error.
  1. Find default.js file in the Java Viewer Web site folder and open it in a text editor.
  2. Find the function named enableFunctions within this file. This function makes a number of enableFunction() calls by passing in the ID and a boolean variable. The ID ranges from 10 to 50.
    See descriptions for IMSMap.enableFunction in 'Customizing ArcIMS : Java Viewer' document available in <ArcIMS Installation Directory>/Documentation folder for more descriptions about this function.
  3. Change the boolean argument to true in the enableFunction corresponding to ID=20:
    Code:
    applet.enableFunction(20, true);
    ID value of 20 corresponds to All Zoom and Pan Functions.
    You can find more information on different ID values in Customizing Java Viewer.pdf file that ships with ArcIMS.
  4. Save the default.js file.
Article ID:000006528
Software:
  • Legacy Products
Get help from ArcGIS experts
Contact technical support
Download the Esri Support App
Go to download options
Discover more on this topic
