ERROR
While using the com.apache.axis.wsdl.WSDL2Java class file to create wrapper Java classes for an https service, the following error occurs:java.io.IOException: Emitter failure. Invalid endpoint address in port IAuthentication in service XXXAdditionally, the generated XXXLocator.java file is blank.
Using the following generic command doesn't work:
Java org.apache.axis.wsdl.WSDL2Java –o .\src –p com.esri.is.servicestests.axis.stubs XXX.wsdl
Article ID:000006404
Get help from ArcGIS experts
Download the Esri Support App
