ERROR
IWorkspaceFactory error -2147220952 License not initialized or -2147467259 Unspecified error
Error Message
While stepping through an ArcObjects ActiveX DLL project in the Visual Basic 6 debugger, opening a workspace displays the following error message:"IWorkspaceFactory::Open, IWorkspaceFactory::OpenFromFile or
IWorkspaceFactory2::OpenFromString throw error -2147220952 (80040228) "License not initialized" or -2147467259 (80004005) "Unspecified error"."The same code runs fine outside the debugger.
Cause
This is due to the way the Visual Basic 6 in-process debugger interacts with ArcGIS 9.2 and its licensing mechanism.
Solution or Workaround
Use Visual C++ 6 to debug the code. See the link in the Related Information section below for more information.
    Article ID:000009303
    Software:
    • ArcMap 9 x
    Get help from ArcGIS experts
    Contact technical support
    Download the Esri Support App
    Go to download options
    Related Information
    Discover more on this topic
