ERROR
Invalid numeric input, bad data in numeric field
Solution or Workaround
Summary
Importing Workstation ArcInfo files produces the following:
Bad data in numeric field
IMPTX6
label error 9010
format # 10
Bad data:
Jaberwocky
Bad buffer:
Line number (this varies)
Cause
UNIX2DOS was used on an interchange file that was already converted to DOS. For instance, moving a series of interchange files with FTP will automatically perform the UNIX2DOS.
Solution
Run an imported file through UNIX2DOS only once. The PC version of this utility does not check if the file has already been converted.
Article ID:000001662
Software:
  • Legacy Products
Get help from ArcGIS experts
Contact technical support
Download the Esri Support App
Go to download options
Related Information
Discover more on this topic
