ERROR
Invalid item value found in index for mapsection
Error Message
This error occurs when using INDEXITEM to index a polygon attribute item GIS_LK for the library layer MGDSTD. The map library name is FORESTLIB and 5770 is a tile workspace for the library.
Arc: LIBRARIAN forestlib
LIBRARIAN Version 7.2.1 Patch 2
You have set Standard library forestlib with Administrator Access.
Librarian: INDEXLAYER mgdstd poly gis_lk
Invalid item value found in index for mapsection D:\KIBRRIES\FORESTLIB\ 5770\mgdstd.
Index not created.
Librarian:
Cause
Unknown
Solution or Workaround
Upgrade to ArcInfo version 8.0.2 or later.
Article ID:000002392
Software:
  • Legacy Products
Get help from ArcGIS experts
Contact technical support
Download the Esri Support App
Go to download options
Discover more on this topic
