ERROR
Installation process error in ArcGIS Survey123 Connect while extracting archive. Cannot open file for writing
Last Published: February 6, 2024
Error Message
When attempting to install ArcGIS Survey123 Connect, the installation fails, and the following error message is returned:
Error:
Error during installation process (com.arcgis.appmake): Error while extracting archive <installer>: Cannot open file <file_path> for writing: Unknown error
Installer error for Survey123 Connect
Cause
The account installing ArcGIS Survey123 Connect does not have read and write permissions on the specified installation folder.
Solution or Workaround
Assign the read and write to the account installing ArcGIS Survey123 Connect
  1. Right-click the installation destination folder and select Properties.
  2. In the <folder_name> Properties dialog box, select the Security tab.
  3. Under Group or user names, click Edit....
  4. In the Permission for <folder_name> dialog box, select the username or group runnning the ArcGIS Survey123 Connect installation.
  5. Under Permissions for <user_name>, uncheck the Read and Write check boxes in the Deny column.
  6. Click Apply.
Permissions and properties dialog boxes
Alternatively, create a new folder or select a different folder as the installation destination folder.
Article ID: 000031845
Software:
  • ArcGIS Survey123 Connect
Get support with AI
Start chatting now
Related Information
Discover more on this topic
Get help from ArcGIS experts
Contact technical support
Start chatting now
Go to download options
