ERROR
This error occurs when attempting to insert or modify features in a layer. For example:
shp2sde -o create -f base_pts -l map_points,shape -u sde -p xxx -e p -g 1000 -x 1831000,861000,100 -a all -r rejects -c 1000
Produces this:
ESRI SDE Shape to Layer Loading Utility Tue Jun 6 16:39:07 2000
SDE Code (-51)= Underlying DBMS error
Extended DBMS error code: -9793
[Informix][Odbc Informix Driver][Informix]User Defined Routine (assign)
module load failed.
S1000
Unable to setup attribute table for insert.
Delete layer "map_points" ...
Informix Spatial DataBlade relies in part on user defined routines (UDFs) to implement geographic data types. When needed, some of those routines are loaded from shared library files. This error occurs when Informix cannot find the shared library files upon start up.
HP-UX: SHLIB_PATH
IBM-AIX: LIBPATH
All other UNIX: LD_LIBRARY_PATH
$INFORMIXDIR/lib
$INFORMIXDIR/lib/esql
$INFORMIXDIR/lib/cli
$SDEHOME/lib
/usr/lib
/lib
Article ID:000001958
Get help from ArcGIS experts
Download the Esri Support App
