ERROR
When starting the installation of ArcGIS, the following error is reported by the Windows Installer:"Incorrect Command Line Parameters.Windows Installer. V 1.10.1029.1
Copyright 1999 Microsoft Corporation. All rights reserved.
Portions of this software are based in part on the work of the Independent JPEG Group"
There may be a space in the network hostname of the computer.
Code:
<CD-ROM drive>:\ArcGIS\ArcView.msi LICENSESERVER=<hostname> ESRI_SETUP=ArcGIS
SEAT_PREFERENCE=Fixed PRODUCTNAME=ArcView DISPLAYNAME=ArcView
Code:
<CD-ROM drive>:\ArcGIS\ArcGIS.msi LICENSESERVER=<hostname> ESRI_SETUP=ArcGIS
SEAT_PREFERENCE=Float PRODUCTNAME=ArcGIS DISPLAYNAME=ArcGIS
Code:
<CD-ROM drive>:\Workstation.msi LICENSESERVER=<hostname> ESRI_SETUP=ArcGIS
<CD-ROM drive> refers to the drive letter of your CD-ROM.
<Hostname> refers to the network hostname of the computer on which you are installing. To check hostname, type hostname at a DOS prompt.
Article ID:000004191
Get help from ArcGIS experts
Download the Esri Support App
