ERROR
Incompatible with current basemap
Last Published: March 28, 2023
Error Message
When opening a layer in Map Viewer, the layer is not added and the following error is returned:
Error:
Incompatible with current basemap.
When hovering over the Exclamation sign symbol, the following warning is displayed.
Error:
This layer's spatial reference is incompatible with the spatial reference of the basemap.
Cause
This is an expected behavior. Different basemaps use different spatial references. When a layer using a different spatial reference is opened in Map Viewer, the layer fails to be added into the map. In the example above, the tile layer is not compatible with the default World Topographic Map basemap.
Solution or Workaround
There are two potential workaround to add the layer. Use one of the following solutions to solve the issue:
Article ID: 000029889
Software:
  • ArcGIS Online
Get support with AI
Start chatting now
Related Information
Discover more on this topic
Get help from ArcGIS experts
Contact technical support
Start chatting now
Go to download options
