ERROR
This error occurs when adding a MrSid image as an image theme to a view:
Where is [filename].sid.After dismissing that message, another is returned:
Error in image source [filename].sid. Unable to make theme.
The TEMP environment variable is set to a folder which is not 8.3 compliant. For example, 'TEMP = c:\documents and settings\users\local settings\temp' will evoke the problem.
Article ID:000002596
Get help from ArcGIS experts
Download the Esri Support App
