ERROR
When attempting to import arcpy using 64-bit Python that comes with an ArcGIS Server installation, the following error message appears:
Error: "ImportError: No module named arcpy"
The arcpy module's location probably is not specified correctly within the Server10.x.pth file. This file is in the following location:
<install-drive>\python27\Lib\site-packages
C:\Program Files\ArcGIS\Server\arcpy C:\Program Files\ArcGIS\Server\bin C:\Program Files\ArcGIS\Server\ArcToolbox\Scripts
C:\Program Files\ArcGIS\Server10.3\arcpy
>>> import sys >>> print sys.path
['', u'c:\\program files\\arcgis\\server\\arcpy', 'C:\\windows\\system32', 'C:\\Python27\\ArcGISx6410.3\\Lib\\idlelib', 'C:\\windows\\system32\\python27.zip', 'C:\\Python27\\ArcGISx6410.3\\DLLs', 'C:\\Python27\\ArcGISx6410.3\\lib', 'C:\\Python27\\ArcGISx6410.3\\lib\\plat-win', 'C:\\Python27\\ArcGISx6410.3\\lib\\lib-tk', 'C:\\Python27\\ArcGISx6410.3', 'C:\\Python27\\ArcGISx6410.3\\lib\\site-packages', 'C:\\Program Files\\ArcGIS\\Server\\bin', 'C:\\Program Files\\ArcGIS\\Server\\ArcPy', 'C:\\Program Files\\ArcGIS\\Server\\ArcToolBox\\Scripts']
Python checks both 'sys.path' and the 'Server10.3.pth' file for a module named 'arcpy' when importing arcpy. As long as the location of arcpy is specified, importing arcpy is successful:
>>> import arcpy >>>
Note: Python 3 is installed in the latest ArcGIS Server to the following location by default: C:\Program Files\ArcGIS\Server\framework\runtime\ArcGIS\bin\Python\Scripts\propy.bat. Refer to ArcGIS Server: ArcGIS Server and ArcPy. Alternatively, refer to Problem: Unable to use the ArcPy module for more information on the issue.
Article ID: 000012627
Get help from ArcGIS experts
Start chatting now
