ERROR
Image mosaicking is not allowed
Error Message
**This issue has been addressed in ArcGIS 8.1.2.**
When appending a raster to an existing raster in a geodatabase, the following error may occur:
"Image mosaicking is not allowed."
Cause
The two rasters may not be aligned cell-wise, have different cell sizes, be of different data types (different bit depth), or the existing raster in the geodatabase does not have a spatial reference specified.
Solution or Workaround
In ArcGIS 8.1, use datasets that align perfectly (don't underlap or overlap), have the same cell size, have the same data type, and have the same coordinate system.
Some sample scripts to workaround this limitation can be found on the ArcObjects Online Web site.
Article ID:000003182
Software:
  • ArcMap 8 x
Get help from ArcGIS experts
Contact technical support
Download the Esri Support App
Go to download options
Related Information
Discover more on this topic
