ERROR
Error getting a list of oids from the table
First Published: May 5, 2016
Error Message
When opening the attribute table for a feature class from a map document containing a geodatabase created from a Unified Modeling Language (UML) diagram using Visio and computer-aided software engineering (CASE) tools, the following error displays:
"Error getting a list of oids from the table
general function failure [substations]
too few parameters expected."
Cause
The ObjectID field is not primary.
Solution or Workaround
Follow the steps below:
  1. Set the ObjectID field as the primary key in Access.
  2. Remove the existing feature class from the map document and add it back in.
Article ID: 000008421
Software:
  • ArcMap
Get support with AI
Start chatting now
Discover more on this topic
Get help from ArcGIS experts
Contact technical support
Start chatting now
Go to download options
