ERROR
These errors occur in ArcView 3.1 when opening a project that was created in ArcView 3.0a:Fun.Jennrich_Turner: Ellipse is both a variable and a class at 6599View.Jennrich_Turner: Ellipse is both a variable and a class at 1934
The extensions Spatial Movement Analysis (SpatialMovement.avx) and Animal Movement Analysis (Movement.avx), distributed by the USGS-Alaska Biological Science Center, use a variable called ellipse. ArcView 3.1 has an Avenue class for ellipse that was not available in ArcView 3.0a. This conflict causes the error messages.
Open the project in ArcView 3.0a and uncheck the Spatial Movement Analysis and/or Animal Movement Analysis extensions. Save the project. You will no longer receive these error messages in ArcView 3.1.
For updates and other information about these extensions, see the link below.
Article ID:000002628
Get help from ArcGIS experts
Download the Esri Support App
