ERROR
Font specified in font.properties not found
Error Message
When trying to launch ArcIMS Administrator on Solaris I get the following error:Font specified in font.properties not found [-monotype-arial-regular-r-normal--*
-%d-*-*-p-*-iso8859-1]
Font specified in font.properties not found [-monotype-courier new-bold-i---*-%d
-*-*-m-*-iso8859-1]
Font specified in font.properties not found [-monotype-times new roman-bold-r---
*-%d-*-*-p-*-iso8859-1].....
Cause
The Font Package ISO-8859-1 (Latin-1) Optional Fonts from Solaris has not been installed. The Font Package installs true type fonts that are necessary in order to run ArcIMS.
Solution or Workaround
  • Confirm whether the font package is installed. From a terminal prompt type:
    Code:
    pkginfo | grep SUNWi1of
  • If you see the following:
    Code:
    system SUNWi1of ISO-8859-1 (Latin-1) Optional Fonts
    You have the required fonts on your system.
  • If not, add them from your Solaris Software installation CD. As an example, from a terminal prompt type:
    Code:
    su pkgadd -d /cdrom/cdrom0/s0/Solaris_2.7/Product SUNWi1of
    Note: For Solaris 8, the font package is installed by default during Solaris 8 installation.
Article ID:000002409
Software:
  • Legacy Products
Get help from ArcGIS experts
Contact technical support
Download the Esri Support App
Go to download options
Discover more on this topic
