ERROR
Floating Point Exception
Error Message
When attempting to print from ArcView while the Image Analyst extension is loaded, the following error may occur:"Floating Point Exception Error"
Cause
There is an incompatibility between older printer drivers associated with the default printer and the Image Analyst extension.
ArcView will also crash with this error when loading an ERDAS Imagine image into a view.
Solution or Workaround
Get the most recent driver for the printer from the vendor. Check the manufacturer's Web site, it may be downloadable.
Article ID:000003541
Software:
  • Legacy Products
Get help from ArcGIS experts
Contact technical support
Download the Esri Support App
Go to download options
Discover more on this topic
