ERROR
The following error message is displayed in the License Manager Tools status enquiry:"License server status: 27004@moo
License file(s) on moo: C:\PROGRA~1\ESRI\License\arcgis9x\arcinfo9.lic:lmgrd is not running: Cannot find SERVER hostname in network database
The lookup for the hostname on the SERVER line in the
license file failed. This often happens when NIS or DNS
or the hosts file is incorrect. Workaround: Use IP-Address
(e.g., 123.456.789.123) instead of hostname
Hostname: moo
License path: 27004@moo
FLEXlm error: -14,7. System Error: 11001 "WinSock: Host not found (HOST_NOT_FOUND)""Where 'moo' is the hostname set in the license files.The license manager debug log file displays the follow error message:"12:00:07 (lmgrd) "mistral": Not a valid server hostname, exiting.
12:00:07 (lmgrd) Valid server hosts are: "moo"
12:00:07 (lmgrd) Using license file "C:\PROGRA~1\ESRI\License\arcgis9x\ARCINFO9.lic""Where 'mistral' is the actual hostname of the computer.
The hostname is set incorrectly in the license files.
Code:
SERVER moo ESRI_SENTINEL_KEY=371xxxxx 27004
Code:
SERVER mistral ESRI_SENTINEL_KEY=371xxxxx 27004
Article ID:000009083
Get help from ArcGIS experts
Download the Esri Support App
