ERROR
File cannot be loaded due to incompatibility in file format or projection information
Error Message
Launching the ArcView Projection Utility returns: "File cannot be loaded due to incompatibility in file format or projection information."
Cause
There is a space or hyphen in the directory path name to the active theme in the view.
Solution or Workaround
Remove the space or hyphen from the path name.
Article ID:000004993
Software:
  • Legacy Products
Get help from ArcGIS experts
Contact technical support
Download the Esri Support App
Go to download options
Related Information
Discover more on this topic
