ERROR
Fatal when using ICurve::QueryTangent for a network edge
Error Message
** Fixed at ArcGIS 8.2 **When acquiring the polyline geometry of a geometric network edge, if the result returns an empty polyline, using the ICurve::QueryTangent method on the empty polyline geometry causes ArcMap to crash.
Cause
This is a known issue.
Solution or Workaround
Use a conditional statement that tests to make sure the geometry is not empty before using ::QueryTangent.
    Article ID:000003795
    Software:
    • ArcMap 8 x
    Get help from ArcGIS experts
    Contact technical support
    Download the Esri Support App
    Go to download options
    Discover more on this topic
