ERROR
FATAL ERROR (VREADR) BAD IREC when executing ADDXY
Error Message
When executing the ADDXY command in Workstation or the 'Add XY Coordinates' tool in ArcToolbox, the process fails with the following error:
"FATAL ERROR (VREADR)
BAD IREC
ISP channel# 1 was not properly closed (INFEND)
Bailing out of ADDXY
ODE sub-process failed"
Cause
The point coverage does not have current point topology.
Solution or Workaround
Build topology for the point coverage.
Code:
Arc: build pointcov point
This error commonly occurs after converting a shapefile to a coverage using the 'Shapefile to Coverage' tool in ArcCatalog or ArcToolbox. This tool creates the new coverage using the LAYEREXPORT command which does not build point topology. The lack of point topology in this coverage is indicated by the COVER# and COVER-ID items having default values of 0 and any subsequent attempt to add XY coordinates to the attribute table will fail.
    Article ID:000006700
    Software:
    • ArcMap 8 x
    • ArcMap 9 x
    • Legacy Products
    Get help from ArcGIS experts
    Contact technical support
    Download the Esri Support App
    Go to download options
    Discover more on this topic
