ERROR
Fatal error - Topological Operator methods
Error Message
This problem is addressed in ArcGIS 8.1 Service Pack 1. See the Related Information section to download this pack.When writing custom code that applies the ITopologicalOperator methods, ensure that the geometry parameters passed in are either polygons, polylines, multipoints, or envelopes.Any type of SEGMENT geometry is not legal for these methods and may result in fatal errors.
Cause
Invalid geometry arguments were passed to the intersect method by the client.
Solution or Workaround
Use a conditional statement that tests to make sure the geometry has the correct type before using the intersect function. If, for example, the objective is to do an intersection using a line, convert the line to a polyline first.
Article ID:000003518
Software:
  • ArcMap 8 x
Get help from ArcGIS experts
Contact technical support
Download the Esri Support App
Go to download options
Related Information
Discover more on this topic
