ERROR
FATAL ERROR, misoriented segment (WRTSEG)
Error Message
This error occurs when running BUILD, CLEAN, INTERSECT, MAPJOIN, BUFFER, or other ArcInfo Workstation commands which affect coverage topology, on a coverage being accessed over a network:
FATAL ERROR
Misoriented segment (WRTSEG)
Bailing out of OVRSEG
Cause
If the data and the ArcInfo installation are in different locations on the network, segments can be written out of order and timing errors can occur.
Solution or Workaround
The best solution is to copy the coverage to the local hard drive, using the ArcInfo COPY command, or using ArcCatalog, before performing these operations. If this is not possible, the steps outlined below may resolve this error.
  • Set the ARCTMPDIR variable to a temp directory on the drive where
    ArcInfo is installed.
    [O-Image] System Properties: Set Variable
  • Set the ARCMEMSIZE variable. This will improve performance if you have sufficient resources. See ArcDOC for information on how to set this variable.
  • Set or increase paging file size (Virtual Memory) on the drive where ArcInfo is installed. For best performance, set Initial and Maximum sizes to the same value.
    [O-Image] System Properties: Set Paging File Size
Article ID:000002415
Software:
  • Legacy Products
Get help from ArcGIS experts
Contact technical support
Download the Esri Support App
Go to download options
Discover more on this topic
