ERROR
FATAL ERROR GetOpenTileChannel: Could not create tile
Error Message
CNVGRID produces this error:FATAL ERROR
GetOpenTileChannel : Could not create tile
Bailing out of CONVGRID
Could not create grid
Cause
When your current workspace directory path name contains spaces, any attempt at utilizing GRID commands or functions will produce a FATAL ERROR.
Solution or Workaround
Before navigating to your current workspace check the entire directory path name and remove any existing spaces.
For Example, if your path name is like this:
c:\my directory\my workspace
Change it to:
c:\mydirectory\myworkspace
Article ID:000002334
Software:
  • ArcMap 8 x
  • Legacy Products
Get help from ArcGIS experts
Contact technical support
Download the Esri Support App
Go to download options
Discover more on this topic
