ERROR
Failed to submit. Arithmetic overflow error converting expression to data type int. The statement has been terminated
Last Published: May 9, 2022
Error Message
Attempts to submit a survey in the ArcGIS Survey123 website return the following error message:
Error:
Failed to submit. Arithmetic overflow error converting expression to data type int. The statement has been terminated.
Error message
Attempts to submit the same survey in the Survey123 field app return the following error message:
Error:
Add error 1000 - Arithmetic overflow error converting expression to data type int. The statement has been terminated.
Error message in the Survey123 field app.
Cause
The integer data type set in ArcGIS Survey123 Connect has a range of valid values that follows the integer data type in SQL Server. This range is from -2^31 (-2,147,483,648) to 2^31 (2,147,483,647). The error occurs when the response value submitted for questions with an integer field type falls outside this range (for example, phone numbers, or a value such as 323 111 0000). Below is a list of possible integer field type sets in ArcGIS Survey123 Connect survey questions.
Field typeValue
typeinteger
bind::esri:fieldTypeesriFieldTypeInteger
bind::type int
Solution or Workaround
As a workaround, use a string (text) field type instead of integer. To do this:
  1. Open the survey in ArcGIS Survey123 Connect.
  2. In the XLSForm of the survey, ensure questions requiring value responses that fall outside the valid range have the field types and values set as follows:
Field typeValue
typetext
bind::esri:fieldTypeesriFieldTypeString
bind::type string
  1. Republish the survey. Refer to ArcGIS Survey123: Publish a survey for more information.
Article ID: 000020979
Software:
  • ArcGIS Survey123 Connect
  • ArcGIS Survey123 Website
Get support with AI
Start chatting now
Related Information
Discover more on this topic
Get help from ArcGIS experts
Contact technical support
Start chatting now
Go to download options
