ERROR
Failed to register with the Geodatabase
Error Message
The following error may occur while attempting to run the 'Register with the Geodatabase' command in ArcCatalog on an annotation layer.
"Register with Geodatabase
Failed to register with the Geodatabase."
Cause
The error occurs if the annotation layer is in the ArcSDE 3.x format. ArcSDE 3.x annotation cannot be converted to geodatabase annotation
Solution or Workaround
ArcSDE 3.x annotation is created by the cov2sde SDE Administration command. To convert the coverage annotation to geodatabase annotation, use the Convert Coverage Annotation command in ArcToolBox instead of the cov2sde command.
    Article ID: 000007602
    Software:
    • ArcMap 8 x
    • ArcMap 9 x
    Download the Esri Support App
    Related Information
    Discover more on this topic
    Get help from ArcGIS experts
    Contact technical support
    Go to download options
