ERROR
Failed to Paste Underlying DBMS error
Error Message
While trying to Copy, Paste or Import existing data as ST_GEOMETRY, one of the following errors is displayed:
Failed to Paste <FEATURE>
Underlying DBMS error[Error executing PL/SQL Block db_stgeom_create_index::ORA-29855: error occured in the execution of ODCIINDEXCREATE routine
ORA-20083: Parameter ST_SRID <SOME NUMBER> does not exist in ST_SPATIAL_REFERENCES table.]
DBMS table not found[<further error info removed>]
or
Underlying DBMS error[Error executing stored procedure <schema>.spref_util.insert_spatial_ref::ORA-01400: cannot insert NULL into ("SDE"."ST_SPATIAL_REFERENCES"."SR_NAME")]
Cause
Previous versions of ArcObjects allowed a Spatial Reference to be defined without supplying a name. This created the Spatial Reference with a NULL name.
For example, it is possible to create a feature with a spatial reference (projection) that consists of a string that contains:
GEOGCS["",DATUM["",SPHEROID["",1.0,0.0]],PRIMEM["",0.0],UNIT["",1.0]]
The ST_GEOMETRY type is OGC-compliant and requires that the feature have a Spatial Reference with a name.
Solution or Workaround
Re-create the spatial reference by using ArcCatalog.
  1. Highlight the feature in ArcCatalog, right-click and select Properties.
  2. Select the XY Coordinate System tab. Use the Select, Import or New options to define the spatial reference.
Article ID:000008862
Software:
  • Legacy Products
  • ArcMap
Get help from ArcGIS experts
Contact technical support
Download the Esri Support App
Go to download options
Discover more on this topic
