ERROR
Failed to federate data store item
First Published: June 4, 2020
Last Published: July 21, 2020
Error Message
When working in a distributed deployment of ArcGIS Enterprise 10.7.1, attempting to federate a data store item to Portal for ArcGIS from the ArcGIS Server admin endpoint returns the following error message:
Error:
Failed to federate data store item <data_store_item_path>. Server machine 'https://machine.domain.com:7443/arcgis/sharing/rest/portals/0123456789ABCDEF/datastores/addToServer'; returned an error. 'Server is not reachable'.
The following error message is displayed in the Portal for ArcGIS logs:
Error:
Invalid SSL certificate found. PKIX path building failed: sun.security.provider.certpath.SunCertPathBuilderException: unable to find valid certification path to requested target.
Cause
The entire chain of certificates is not imported in both the Portal for ArcGIS and ArcGIS Server admin endpoints. In a distributed environment, this impacts various functionality within the Portal for ArcGIS interface.
Solution or Workaround
Perform the following workaround to resolve:
  1. Navigate to the Portal for ArcGIS admin endpoint, and log in with an administrator account.
  2. Navigate to Security > SSLCertificates > Import Root or Intermediate Certificate.
  3. Click Choose File, and select the chain of certificates to import. Click Import to begin the import process, and restart Portal for ArcGIS.
  4. Navigate to the ArcGIS Server admin endpoint, and log in with an administrator account.
  5. Navigate to machines > machine_name > sslcertificates > importRootOrIntermediate.
  6. Click Choose File, and select the chain of certificates to import. Click Import to begin the import process, and restart ArcGIS Server.
  7. Log in to the ArcGIS Server admin endpoint.
  8. Navigate to data > federateDataItem. Enter the item path for the registered data store, and click Federate Data Item.
The operation completes successfully. To verify, log in to the Portal for ArcGIS home page, and select Content. The data store item is listed here.
Article ID: 000023475
Software:
  • Portal for ArcGIS
  • ArcGIS Server
Get support with AI
Start chatting now
Related Information
Discover more on this topic
Get help from ArcGIS experts
Contact technical support
Start chatting now
Go to download options
