ERROR
Failed to evaluate the calculator expression
Error Message
The error message "Failed to evaluate the calculator equation" appears after clicking Evaluate on the Raster Calculator dialog box.
Cause
There are several causes for this problem:
· You have a syntax error in the calculator expression.
· The extent and cell size of your input raster is different than the extent set for your analysis results.
· The expression will not be evaluated if there are carriage returns before or after the expression.
· The Raster Calculator is case sensitive.
· There are too many open grids. There is a limit of 50 open rasters of the grid format at any one time.
Solution or Workaround
Some of these issues have been addressed in ArcGIS Version 8.1.2.
The corresponding workarounds for the above causes are:
  • Check your syntax. Type Map Algebra in the index of the online Help system for information on Map Algebra and its syntax.
  • Make sure the extent and cell size of your analysis result is set appropriately in the Extent and cell size tabs of the Options dialog box. The extent of your analysis results should be set the same as, or encompass, the extent of the layer you are using in the Raster Calculator.
  • Do not use carriage returns in your expression. Allow the expression to word-wrap if it is lengthy.
    This problem has been resolved in ArcGIS 8.1.2.
  • Make sure the layer name typed into the expression box case-matches the name of the layer in the Layers list. For example:
    Layer name: Elevation
    Expression typed: slope([elevation])
    This expression will not work. The first letter of "elevation" should be capitalized.
  • Remove any un-needed grids from the ArcMap Table of Contents. The total number of open grids, including the one being created by the Spatial Analyst function, cannot exceed 50.
    This limit does not apply to non-grid rasters. A workaround is to convert grids to rasters in ArcCatalog with the Export > Raster To Different Format option.
Article ID:000003325
Software:
  • ArcMap 8 x
Get help from ArcGIS experts
Contact technical support
Download the Esri Support App
Go to download options
Related Information
Discover more on this topic
