ERROR
Failed to create replica. Multiple layers are referencing a dataset, which is not supported
First Published: April 27, 2022
Last Published: April 27, 2022
Error Message
When attempting to download offline maps in ArcGIS Pro or ArcGIS Field Maps, the download fails, and the following error messages are returned in the ArcGIS Server Manager logs, and ArcGIS Pro, respectively.
In ArcGIS Server Manager
Error:
Failed to create replica. Multiple layers are referencing a dataset, which is not supported.
The error messaged is returned in ArcGIS Server Manager.
In ArcGIS Pro
Error:
Create Offline Features Error: { Create Offline Features Error for: <layerdatasource> }
The error messaged is returned in ArcGIS Pro.
Cause
The feature service in ArcGIS Server or Portal for ArcGIS contains two or more layers based on the same feature class. Feature services with multiple layers referencing the same feature class cannot be taken offline even though the Enable Sync capabilities are enabled on the item details page. Refer to ArcGIS Enterprise: Feature service preparation for more information.
Solution or Workaround
Use one of the following solutions to resolve the issue.
  • In ArcGIS Pro, create a feature class for every layer in the map, so there is only one layer referencing the feature class. Republish the map to ArcGIS Server or Portal for ArcGIS.
  • Remove the layer referencing the same feature class and republish the map.
Article ID: 000027576
Software:
  • ArcGIS Pro
  • ArcGIS Server
  • ArcGIS Field Maps Android
Get support with AI
Start chatting now
Related Information
Discover more on this topic
Get help from ArcGIS experts
Contact technical support
Start chatting now
Go to download options
