ERROR
In ArcGIS Pro, attempting to create a new feature fails and returns the following error message:
Error: Failed to create <feature class name>.
Value doesn't fall within Domain: <domain name>
The selected feature class has fields with assigned attribute domains. When creating features that are part of attribute domains, if no null value or attribute value is assigned beforehand, this leads to missing symbology attribute values. Attribute domains are rules that describe the available values of a field type and limit that can be placed on a field; therefore, creating features that are part of attribute domains requires an assigned value to ensure data integrity.
Perform one of the workarounds provided below before creating a new feature to resolve the error.
Set a default domain value for the feature class field
Assign a null value to the attributes field
Assign an attribute value in the Active Template pane
Turn attribute validation off
Turn attribute validation off to override the validation criteria imposed on the field. Refer to ArcGIS Pro: Turn attribute validation on or off for instructions.
Note: Turning attribute validation off and creating a new feature results in a blank (text data type) or '0' (numeric data type) field value.
Article ID: 000031397
Get help from ArcGIS experts
Download the Esri Support App
You can also download the app to access the chatbot anytime! Download it now.
