ERROR
Failed to create feature class
Error Message
When attempting to convert labels to geodatabase annotation in ArcMap, or create a new annotation feature class in ArcCatalog, the following error is produced:"Failed to create feature class. The edit that you have made is not supported in earlier versions of the Geodatabase. You must upgrade your Geodatabase to the current version in order to edit it."
Cause
Changes that took place at the ArcGIS 9.0 release require that the geodatabase being edited be upgraded to a newer version.
Solution or Workaround
  1. Close ArcMap, if it is open.
  2. Start ArcCatalog.
  3. Make a backup copy of the pre-9.0 version personal geodatabase.
  4. Right-click the geodatabase to be upgraded and select Properties.
  5. Click the General tab.
  6. Click 'Upgrade Personal Geodatabase'.
  7. Click OK.
Article ID:000006897
Software:
  • ArcMap 9 x
Get help from ArcGIS experts
Contact technical support
Download the Esri Support App
Go to download options
Discover more on this topic
