ERROR
Failed to connect to source portal
Last Published: March 8, 2021
Error Message
Attempting to use the ArcGIS Solutions Deployment tool in ArcGIS Pro returns the error message:
Error:
Occasionally, the following error message is also returned:
Error:
Failed to add <name of solution>
Cause
A proxy server or firewall is blocking the connection to ArcGIS Online.
Solution or Workaround
To resolve the issue:
  1. Navigate to Control Panel > Network and Internet > Internet Options. The Internet Properties window opens.
  2. Select the Security tab.
  3. Click Trusted Sites > Sites.
  4. Add the following domains to the list, individually:
*.arcgis.com
*.arcgisonline.com
*.amazonaws.com
*.virtualearth.net
*.esri.com
  1. Click Close > OK.
In some organizations, the IT team may also need to allow the domains in Step 4 on the organization's proxy server and/or firewall.
Article ID: 000019982
Software:
  • ArcGIS Pro 2 x
Get support with AI
Start chatting now
Related Information
Discover more on this topic
Get help from ArcGIS experts
Contact technical support
Start chatting now
Go to download options
