ERROR
Failed to connect to database. The geodatabase is not accepting connections. Please contact your geodatabase administrator
Error Message
In ArcGIS for Desktop, when attempting to establish a connection to a geodatabase, the following error is returned:
Error:
Failed to connect to database. The geodatabase is not accepting connections. Please contact your geodatabase administrator.
image of error message
Cause
The 'Geodatabase is accepting connections' check box is unchecked in the database properties, which prevents new connections to be made to the geodatabase.
Solution or Workaround
Enable the Geodatabase is accepting connections option.
Only a geodatabase administrator can apply the steps provided below.
  1. In ArcMap, navigate to the Catalog pane.
  2. Right-click the target database > Properties > Connections tab.
  3. Check the Geodatabase is accepting connections check box.
  4. Click Apply to confirm the new database connection settings.
Article ID: 000014329
Software:
  • ArcMap
Get support with AI
Start chatting now
Related Information
Discover more on this topic
Get help from ArcGIS experts
Contact technical support
Start chatting now
Go to download options
