ERROR
Failed to compress the database. Operation Failed [sde.default]
Error Message
The following error occurs when the 'sde' user compress using ArcCatalog tools."Failed to compress the database
Operation Failed [sde.default]"
Cause
If the 'sde' user does not have 'View Server State' permission at the instance level in SQL Server 2005, compressing with ArcCatalog will fail.
Compressing with 'sdeversion -o' works successfully.
Solution or Workaround
  1. On the machine where SQL Server 2005 is installed, navigate to Start > Programs > Microsoft SQL Server 2005 > SQL Server Management Studio.
  2. Highlight and right-click the instance and click Properties.
  3. In the Server Properties window:
    A. Select 'Permissions'.
    B. Highlight the 'sde' user. Verify the user has 'View Server State' permission available.
    C. Click the check box under 'Grant' for the 'View Server State' permission.
    [O-Image]
Article ID:000008907
Software:
  • Legacy Products
  • ArcMap 9 x
Get help from ArcGIS experts
Contact technical support
Download the Esri Support App
Go to download options
Related Information
Discover more on this topic
