ERROR
In ArcGIS Pro, attempts to run any geoprocessing tools return the following error message:
Error: Failed to check sharing process status
Reviewing the Job Status pane indicates a failed task exists in the job queue. Clicking the remove button does not remove the failed task.
This issue occurs when an attempt to share content to ArcGIS Online is made and if the sharing process fails. As the task has failed to complete, the job request is left in the Job Queue which prevents other jobs from being processed.
To resolve this issue, manually clear the job queue with the following steps:
C:\Users\<username>\AppData\Local\ESRI\ArcGISPro\Staging\SharingProcesses
Article ID: 000019192
Get help from ArcGIS experts
Start chatting now
